ALFY_NET
Sep 24, 2023Aspirant
Nighthawk R7000P in access mode only accepts 2 devices
Hi,
I have this router configured as "access mode" because I need to access devices connected to this wireless router, my firewall is providing ip addresses through firewall dhcp and 20 IPs are ava...
ALFY_NET
Sep 25, 2023Aspirant
I have a Cisco ASA in front of the Nighthawk and has dhcp enable with 20 ip addresses available.
michaelkenward
Sep 26, 2023Guru - Experienced User
You may have to explain how that fits into the network.
Netgear's routers are designed to sit behind a modem of some sort or, in AP mode, behind a router.
The circumstances you describe seem to be rare. Anything that has appeared might be here:
Search - NETGEAR Communities – cisco asa
It might also make sense to ask Cisco how you are supposed to attach things to its hardware.
