ayush0963
May 09, 2023Follower
Nighthawk R7000P is capping my Steam download speeds and I don't know why
I get about 600Mbps bandwidth from my ISP and when connected directly to my modem, I see speeds up to 74Mbps.
When I'm connected directly to my Nighthawk R7000P, I still see bandwidth speeds around 600Mbps but for some reason Steam downloads will not exceed 20Mbps.
I have searched tirelessly online for a solution but have found none. Can someone please help?
https://www.reddit.com/r/NETGEAR/comments/13bmpff/nighthawk_r7000p_is_capping_my_steam_download
That doesn't make sense.
600 Mpbs in and 74 Mbps out?
What is this modem?
- KitsapMaster
You are comparing two different units of measure. From your ISP you are indicating 600 Mbps (megabit per second). For your other numbers you are indicating MB/s (megabyte per second).
There are 8 bits in a byte. So, 600 Mbps compares reasonably well to 74 MB/s or 592 Mbps.
Check the original message. It was all mbps. No mention of Mbps.
- KitsapMaster
michaelkenward wrote:Check the original message. It was all mbps. No mention of Mbps.
There is a difference between mbps and mb/s. The later is usually indicative of megabyte and the former megabit. See attached.
