MostafaBadawy
Oct 15, 2023Aspirant
Nighthawk R7000P is on and off internet over 5G
Hello, 2.4 is working fine all the time, but for the 5 G, I can find that the laptop keeps disconnecting and connecting sometimes this happens more than 2 times per hour for no reason. But sometime...
MostafaBadawy
Oct 16, 2023Aspirant
Hi Kitsap,
Thank you for your fast response.
My modem is: ARRIS - SURFboard SB6190 32 x 8 DOCSIS 3.0 Cable Modem,
The Router Firmware version is V1.3.3.154_10.1.86.
I don't know the neighbors broadcasting Wi-Fi on the 5 GHz band.
Kitsap
Oct 16, 2023Master
MostafaBadawy wrote:Hi Kitsap,
Good things. Your modem is a modem only and not a combination modem/router. Your router firmware is current.
Log in to the user interface and check your 5 GHz Wi-Fi settings for channel, mode, and security. Usually under the Advanced -> Setup -> Wireless Setup tab. DFS channels can occasionally be knocked off line. See attached screen snip. I recommend Smart Connect be disabled so you have different SSIDs for the different bands.
Your radio frequency environment (neighbors) can have an impact on your connection. There are a couple of scanning applications for mobile devices that can give you a picture of your situation. I use an Android device. There is a section in the Netgear mobile application called Wi-Fi Analytics and there is an application called WiFiman from Ubiquiti. They should be available in the Play Store of your mobile device. Look to see if the 5 GHz channel you are using is broadcasting the same as your neighbors or on a DFS channel.
Wi-Fi has a lot of variables that impact your connection and your satisfaction with performance. Some background reading to help your understanding can be found here: https://www.duckware.com/tech/wifi-in-the-us.html. Duckware is a good reference. Do not try to swallow the whole thing at one time. Review of the first few chapters is a good start.
- MostafaBadawyOct 16, 2023Aspirant
My router configuration already has your requested configuration.
Please find the Wi-Fi analysis attached
