MostafaBadawy
Oct 15, 2023Aspirant
Nighthawk R7000P is on and off internet over 5G
Hello, 2.4 is working fine all the time, but for the 5 G, I can find that the laptop keeps disconnecting and connecting sometimes this happens more than 2 times per hour for no reason. But sometime...
michaelkenward
Oct 16, 2023Guru - Experienced User
MostafaBadawy wrote:
But sometimes if the phone wifi is off and I make it one, the 5G network will be restarted and then work normally, and if I make the phone wifi off and on again the issue will be repeated.
It can be hard to work out of this sort of thing is due to the router or to the wifi client you are using.
Do all 5 GHz clients experience the same issue?
Does the wifi client behave properly with different wifi sources?
Are any of the anonymous clients Apple devices?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
