calbar
Feb 06, 2022Aspirant
Nighthawk R7000P Keeps Restarting
As the subject states, my R7000P keeps restarting. It's about a year 10months old so I don't think age is an issue? This behavior has occurred randomly with no pattern within the past year but re...
Feb 06, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Have you tried reverting back to prior FW version that had been working?
- calbarFeb 06, 2022Aspirant
Thanks for your response!
Not sure what MFR stands for but the modem is an Arris SB6103. Modem behavior is fine - nothing happens to it when internet goes down though.
I'll try the wifi channel change and will have to follow-up in a few days if that does or doesn't change anything. Out of curiosity - how would the changing the channels affect the router restarting? From what I understand, changing channels only affects speed. Also, the two desktops are connected via ethernet but their internet still goes down when the router restarts itself so I'm not sure if the channels could be the cause. Again, I will follow-up since I did try this and didn't change include this in my troubleshooting.
We do have quite a few WiFi neighbors as we live in a townhouse but I don't think that's an issue as we haven't had any recent moves by neighbors or changes to surrounding area wifi. I think there's about 8 unique connections/WiFi I can connect to?
I didn't try reverting but that previous FW wasn't really working/I don't think that's the issue since the router was already restarting frequently on previous FW. Updating did not help.
- FURRYe38Feb 06, 2022Guru - Experienced User
Having wifi neighbors near by can cause the router to reboot to restart and find a new channel thats less congested or less interference is one cause.
- calbarFeb 08, 2022Aspirant
I was using Auto on 5Ghz. I have tried 48, 151, 168 with no luck. I ran some command on cmd prompt to pick those upper ones since no other routers in my area were using those. Trying 40 right now.
On 2.4 I've tried 1, 6, and trying 11 right now.
I have not done a factory reset on the new FW yet so I'll give that a go if the router restarts again on those other channels.
