calbar
Feb 06, 2022Aspirant
Nighthawk R7000P Keeps Restarting
As the subject states, my R7000P keeps restarting. It's about a year 10months old so I don't think age is an issue? This behavior has occurred randomly with no pattern within the past year but re...
calbar
Feb 10, 2022Aspirant
That will void my warranty though, no?
michaelkenward
Feb 11, 2022Guru - Experienced User
If it is still in warranty, go down that route.
- calbarFeb 11, 2022Aspirant
Yes, I submitted a warranty ticket around the time I asked the forum for help. I thought I'd see if I could learn some new troubleshooting or try everything I could to do fix it while I wait for customer service to get back to me.
Still waiting on a response but yeah, definitely seems like I'll have to use my warranty.
- michaelkenwardFeb 11, 2022Guru - Experienced User
One simple thing to try that I haven't seen mentioned is a different power adapter.
They are pretty generic so you may have something suitable lying around. Especially if, like me, you have loads of old kit lying around awaiting the great recycler in the sky.
- wcalifasFeb 11, 2022Prodigy
I mean you can flash it with dd-wrt and if it doesn't work out, you can re-flash it back to netgear firmware again.
- michaelkenwardFeb 12, 2022Guru - Experienced User
Nothing wrong with that, but when you flash third-party firmware, make a note on how to get it back to the stock firmware. And save copies of any essential files.
I mention that because we see a steady trickle of messages here from people crying "Help, how do I get back to Netgear firmware?"
Netgear doesn't support other firmware, so this isn't the best place to ask for that sort of help.
The third party firmware sites are usually pretty good at explaining how to go about that, but it is a good idea to be prepared before you make the jump.
