Harmlessluv
Nov 30, 2021Guide
Nighthawk R7000p no internet connection
Hi guys, so I set this router up 4 months ago (can't remember how I did it either). I was told to reset it by my internet provider which has led to no internet connection on the router login website a...
- Nov 30, 2021
I think that ONT needs vlan enabled. I've seen a couple posts about it.
this article is for spark NZ fibre or UFB.
https://kb.netgear.com/30947/How-do-I-set-up-my-NETGEAR-router-if-I-have-Spark-NZ-Fibre-or-UFB
Not sure what actual vlan ID you need.
Harmlessluv
Nov 30, 2021Guide
How can I find this out?
Nov 30, 2021Guru - Experienced User
You look at what you're plugging the router into that supplies an internet connection. There should be a label on it.
- HarmlessluvNov 30, 2021GuideSo I'm plugging it into a fibre box (pictured below) for its internet connection
- plemansNov 30, 2021Guru - Experienced User
- HarmlessluvNov 30, 2021GuideThank you so much this actually worked, I appreciate the help!!
