Harmlessluv
Nov 30, 2021Guide
Nighthawk R7000p no internet connection
Hi guys, so I set this router up 4 months ago (can't remember how I did it either). I was told to reset it by my internet provider which has led to no internet connection on the router login website a...
- Nov 30, 2021
I think that ONT needs vlan enabled. I've seen a couple posts about it.
this article is for spark NZ fibre or UFB.
https://kb.netgear.com/30947/How-do-I-set-up-my-NETGEAR-router-if-I-have-Spark-NZ-Fibre-or-UFB
Not sure what actual vlan ID you need.
Harmlessluv
Nov 30, 2021Guide
So I'm plugging it into a fibre box (pictured below) for its internet connection
Nov 30, 2021Guru - Experienced User
- HarmlessluvNov 30, 2021GuideThank you so much this actually worked, I appreciate the help!!
- plemansNov 30, 2021Guru - Experienced User
glad it helped! if you the answer solved, it might help the next person with that issue :)
Mind posting who the isp is and what vlan id you used? That way if someone else runs into this issue, they know what settings you used to get it to connect.
