carr433
Apr 19, 2021Aspirant
NIGHTHAWK R7000p not allowing cisco SPA509G phone to connect
I just purchased a Nighthawk R7000p WIFI router. Connecting to computers, phones, and printers works great. The issue I am having is it won't allow my cisco work phone to connect. It shows it is conn...
carr433
I will go in and check shortly and get back to you. Currently have my Spectrum WIFI router connected so i can still work. If it is disabled do you have any other recommendations I could try?
Thank you
Apr 19, 2021Guru - Experienced User
Potentially putting the phone's ip address into the netgear's dmz.
