gmpaixao
Jun 13, 2019Aspirant
Nighthawk R7000P not working after firmware upgrade to v1.3.1.44
Hi, Yesterday night upgrade my Netgear Nighthawk R7000P (AC2300), using Admin page (192.168.1.1), after 30 minutes the amber light kept flashing, I went to sleep hoping the process will be finish d...
- Jun 13, 2019
Here is a step by step writeup of recovering a r7000 via tftp using a MAC written by a Senior Designer.
Will work fine for a r7000p as well. Only real issue is does the MAC have an Ethernet port. If not then you will need a USB to Ethernet dongle.
I have done this procedure on a r8000 using a MACbook Pro with dongle and know it works. Will see some non english in some of the screen shots.
gmpaixao
Thanks for your answer, I’ll try later.
Is this tftp procedure possible in MacOS?
Thanks again
Thanks again
Jun 13, 2019Guru - Experienced User
Yes. You just need to use a client though.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- myerswJun 13, 2019Master
