JJFlash73
Jul 28, 2021Aspirant
Nighthawk R7000P questions
HI, New provised in my area is bringing in Fiber Optic and I have been given a list of routers to use. My home is 2 stories and is 2250SF. From everything I can read, this will work fine on my ho...
- Jul 29, 2021
> The AC1900 unit I have is a model C7000v2. Could it possibly work with
> fiber optic or is it "iffy" [...]It's beyond "iffy". Netgear Cxxxx models lack an Ethernet
WAN/Internet port, which makes them useless as routers except with a
cable-TV ISP. (Hence "Rxxxx", above.)> The new provider does offer a list of fiber optic routers that they
> recommend [...]I don't follow this stuff closely enough to recommend particular
devices, and I have no idea on what your ISP bases its recommendations.
I also don't know how fast your fiber service would be. The R7000P is
not a very recent model. You might search these forums for any model
number to see what kinds of complaints it generates.> [...] the local rep stated to lean towards the Netgear units [...]
I'd explore more broadly. If your ISP recommends any Netgear Rxxxx
model, then practically any router (but not a cable modem+router) should
be compatible. Maker, performance, features, and cost are variables
which you'll need to juggle. Presumably, a search of this new Inter-Web
thing could find reviews of various routers. Or someone else might
suggest something(s) here.
antinode
Jul 28, 2021Guru
> given a list of routers to use. [...]
With my weak psychic powers, I can't guess who that ISP is, or what's
on that list. Is the R7000P on it? What is?
> [...] will I need a modem with this unit [...]
That depends on what sort of equipment your ISP is providing. This
might seem radical, but did you try asking your (unspecified) ISP what's
required?
