Luc1d_catto
Nov 17, 2024Follower
Nighthawk R7000P won’t connect to the app or webpage can’t setup router router not found
I can’t see what firmware it’s on Netgear won’t replace it all leds are while but I can’t set it up on the mobile app or access it on the webpage
michaelkenward
Nov 18, 2024Guru - Experienced User
If there is one it might help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Just another user with time on their hands.
