SirloinSteak239
Jan 13, 2021Aspirant
Nighthawk R7000P wont work with LG TV unless connected directly
I have:Netgear R7000P, Fios (ONT located in hall closet with patch panel to reach outlets in varios rooms), LG OLED C8 (WEbOS) TV If I connect the ethernet cable from the Verizon Fios ONT directl...
SirloinSteak239
Jan 20, 2021Aspirant
No, I'm not using a fios modem per se. The fios ONT is set up in "bring your own device" mode with just one ethernet cable coming out and connecting to the WAN port on the router.
michaelkenward
Jan 21, 2021Guru - Experienced User
