aliaa
Mar 23, 2024Aspirant
Nighthawk R7000P
I'm hoping someone can help. We live in a mobile phone blackspot - no signal at all- and I've been trying for a very long time to work out how to use wifi calling. My phone (Samsung S20 FE) has the c...
Apr 17, 2024Guru - Experienced User
Any progress on this?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
aliaa wrote:
I'm hoping someone can help. We live in a mobile phone blackspot - no signal at all- and I've been trying for a very long time to work out how to use wifi calling. My phone (Samsung S20 FE) has the capability and my service provider provides the service, but no luck. Recently, I found info on the internet to the effect that the problem was with the router. As a result, I have disabled the Sip ALG and selected the 'open' setting as suggested online.
As a result, I had a very brief period of time (as in minutes) where I was able to check messages on my mobile phone, then the wifi calling notification
icon disappeared and I haven't been able to get it back. Until last night when it was randomly back again. However, after leaving my home wifi range, it was gone again.
Can anyone tell me what I have to do in order to get this feature to work properly?
TIA
