Shirox
Mar 06, 2021Aspirant
Nighthawk r700p drops 5G network
So today out of no where my Nighthawk r7000p 5g network stopped working on all my devices connected to the 5G. I went into the nighthawk app thinking I may have accidently turned it off or something ...
- Mar 08, 2021
the newer version of firmware is out. Its version 1.3.2.134
I'd highly recommend against updating via the app. Its supposed to be all hosted on the router but when I've seen corrupt firmware issues, its tends to be when done via the app.
So try installing it over a hardwired connection. then do a factory reset and clean install (not from a backup configuration).
See if that helps.
Nighthawk R7000P | AC2300 Smart WiFi Router | NETGEAR Support
michaelkenward
Mar 07, 2021Guru - Experienced User
I assume that you have tried a network reboot. (You don't say.)
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- ShiroxMar 07, 2021Aspirant
I have tried that shortly after posting and had no change. the router is right next to my modem ive not had any issues with it until literally last night after 11 months of having this in the same spot.
- plemansMar 08, 2021Guru - Experienced User
See if that helps.
- bdnmnMar 09, 2021Aspirant
I've been running the latest version of firmware V1.3.2.134_10.1.66 for several weeks and the issue with 5GHz connections dropping is still happening. If my phone and laptop are on the 5GHz network they both drop the connection randomly. I have to keep one on 2.4GHz network to avoid the conflict.
Anyone have a real solution?
