Shirox's avatar
Shirox
Nighthawk r700p drops 5G network
So today out of no where my Nighthawk r7000p 5g network stopped working on all my devices connected to the 5G. I went into the nighthawk app thinking I may have accidently turned it off or something ...
  • plemans's avatar
    Mar 08, 2021
    the newer version of firmware is out. Its version 1.3.2.134
    I'd highly recommend against updating via the app. Its supposed to be all hosted on the router but when I've seen corrupt firmware issues, its tends to be when done via the app.
    So try installing it over a hardwired connection. then do a factory reset and clean install (not from a backup configuration).
    See if that helps.
    Nighthawk R7000P | AC2300 Smart WiFi Router | NETGEAR Support
