ratwagon-502
Oct 16, 2021Guide
Nighthawk R700P Will Not Download Apps To My Android Moto Z4
My Nighthawk Router Model # R7000P Downloads Comcast Internet and TV Streaming and Connects to My Printer and my Android Motorola Phone Moto Z4 with no problems. My Download speeds thru comcast are ....
- Oct 17, 2021
plemans wrote:How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
"Try using a different dns provider like google at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1"
Thanks for your help. I appreciate all the time you have given me. But at this point I have had it. This is the 2nd Nighthawk same model I have had that has given me a PITA. The first one locked up after clicking on the factory update link in the router view. After calling support which was in another country I came away after 1.5 hours with a dead router. Now out of no where this one decides to not donload apps from the play store thru WiFi. It was fine for a year but now is causing me to hunt remidies on the web and sign into forums like this one which are helpful but time consuming.
So, I just went out and bought a New Sony Router with phone support in the USA. Should be here tomorrow. I also have a another Netgear Router AC2300 (R7000P) in the box. I'll blow that out cheap
Again Thanks For Your Help....It's time to move on with my life and get off the keyboard.
Regards: Mark..(Ratwagon-65)
ratwagon-502
Oct 16, 2021Guide
Thanks for the reply Plemans,
No I did not change the original settings...admin...password Etc. pretty sure i did lower case when entering the User and PW. So that's on me as this stuff is not my forta. Thank goodness there are smart people like you to help.
"What modem/gateway is the r7000P connected to?" .......
It is a Surfboard... #SB6190 Brand is "Arris"
"What firmware version are you on?"
Just went out to netgear and checked.My R7000P has the Latest Firmware as per Netgear Computer Check. It Is FIrm V
V1.3.2.134
"Are all devices having issues or jus tthe moto Z?"
Just The Moto Z..everything else is fine... Got me confused????
Also..Managed to log into the router settings...found my correct PW.
Thanks Again for the Help.
Mark
Oct 17, 2021Guru - Experienced User
Are you using armor? or parental controls?
Using a different DNS provider?
do you have IPv6 enabled/disabled?
- ratwagon-502Oct 17, 2021Guide
plemans wrote:Are you using armor? or parental controls?
Don't know if it is on or off. Would that be found under router settings, did not see that? ?? No parental Controls..
"DNS"....Using Comcast direct with one computer thru The Nighthawk Router
Don't know how to check to see that.. When I loged into router settings I did not see this Setting. Where would that be?
- plemansOct 17, 2021Guru - Experienced User
