ratwagon-502's avatar
Oct 16, 2021
Nighthawk R700P Will Not Download Apps To My Android Moto Z4
My Nighthawk Router Model # R7000P Downloads Comcast Internet and TV Streaming and Connects to My Printer and my Android Motorola Phone Moto Z4 with no problems. My Download speeds thru comcast are ....
  • ratwagon-502's avatar
    ratwagon-502
    Oct 17, 2021
    plemans wrote:
    How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
    "Try using a different dns provider like google at 8.8.8.8 or 8.8.4.4
    or cloudfare at 1.1.1.1"
    Thanks for your help. I appreciate all the time you have given me. But at this point I have had it. This is the 2nd Nighthawk same model I have had that has given me a PITA.  The first one locked up after clicking on the factory update link in the router view. After calling support which was in another country I came away after 1.5 hours with a dead router.  Now out of no where this one decides to not donload apps from the play store thru WiFi. It was fine for a year but now is causing me to hunt remidies on the web and sign into forums like this one which are helpful but time consuming.
    So, I just went out and bought a New Sony Router with phone support in the USA. Should be here tomorrow. I also have a another  Netgear Router AC2300 (R7000P) in the box. I'll blow that out cheap
    Again Thanks For Your Help....It's time to move on with my life and get off the keyboard.
    Regards: Mark..(Ratwagon-65)
