ratwagon-502
Oct 16, 2021Guide
Nighthawk R700P Will Not Download Apps To My Android Moto Z4
My Nighthawk Router Model # R7000P Downloads Comcast Internet and TV Streaming and Connects to My Printer and my Android Motorola Phone Moto Z4 with no problems. My Download speeds thru comcast are ....
- Oct 17, 2021
plemans wrote:How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
"Try using a different dns provider like google at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1"
Thanks for your help. I appreciate all the time you have given me. But at this point I have had it. This is the 2nd Nighthawk same model I have had that has given me a PITA. The first one locked up after clicking on the factory update link in the router view. After calling support which was in another country I came away after 1.5 hours with a dead router. Now out of no where this one decides to not donload apps from the play store thru WiFi. It was fine for a year but now is causing me to hunt remidies on the web and sign into forums like this one which are helpful but time consuming.
So, I just went out and bought a New Sony Router with phone support in the USA. Should be here tomorrow. I also have a another Netgear Router AC2300 (R7000P) in the box. I'll blow that out cheap
Again Thanks For Your Help....It's time to move on with my life and get off the keyboard.
Regards: Mark..(Ratwagon-65)
Oct 18, 2021Guru - Experienced User
Good luck with your next device!
to be honest, I didn't know sony made routers.
What model did you find as I couldn't find any?
ratwagon-502
Oct 18, 2021Guide
Here it is:
Motorola AC2600 4x4 WiFi Smart Gigabit Router with Extended Range, Model MR2600:...
About this item
- The Motorola AC2600 router provides a high-speed intelligent router link between all your WiFi and Ethernet devices and whatever Ethernet-capable modem you choose for Internet access. The MR2600 delivers very high speeds and extended range even when you’re far from your router or surrounded by WiFi noise from neighbors. (Note that this router does not have a built-in cable modem or other type of modem.)
- Connects via AC2600 dual band WiFi or Gigabit Ethernet to all your HDTVs, smartphones, game stations, computers, tablets, and more. Netflix, YouTube, Amazon Video, gaming connections and much more can be delivered many devices at the same time through the MR2600’s 4 Gigabit LAN ports or through WiFi.
- Four external adjustable antennas provide concurrent 4X4 performance for both 5 GHz and 2.4 GHz connections. 802.11ac Wave 2 MU-MIMO technology dramatically speeds up your network, allowing high-speed communication with multiple WiFi devices.
- Implicit and explicit Beamforming targets the WiFi signal to each of your WiFi devices resulting in blazing fast WiFi speeds and extended range.
- Router features include a USB 3.0 port with DLNA media sharing support, a Dual Core processor, Smart QoS (Quality of Service) support, user-friendly firewall, IPv4 and IPv6 support, parental controls, guest network capability, and more. Expert, friendly support from the USA. 2 year warranty from Motorola, a company you trust.
- plemansOct 18, 2021Guru - Experienced User
Got it. Not a sony but a motorola.
Makes a little more sense. Looks like a reasonable device.
- ratwagon-502Oct 18, 2021Guide
Yep I messed up I was thing Moto but typed Sony..L.O.L. Tried to post a pic but the fourm Blocked it.. Google it.
