X1l1's avatar
X1l1
Nighthawk R7300 2.4Ghz Disconnecting/Disabling
I have a Nighthawk R7300 router and when I start a large download (anything greater than 10 gigabytes) on my playstation 4, I find my router's 2.4 band (the one that the PS4 is connected to) becomes ...
  • ElaineM's avatar
    ElaineM
    Nov 07, 2017
    I would suggest that you contact Geeksquad for replacement.
    If in any case you would experience the same issue, feel free to let me know.
