MommaRoth
Nov 05, 2016Aspirant
Nighthawk r7300 doesn't recognize external hard drive
Hi all - (I searched for this in the community but didn't quite find the solution. If I've missed it please post a link & sorry for the trouble!) I run a small home office and recently bought a ...
- Nov 18, 2016
Hi ElaineM
Thanks for your response. I ended up returning the drive - no amount of partitioning or driver-downloads made it readable. I'm going to go back to the list of recommended external hard drives and see if I can find an exact match. I must say it's incredibly frustrating that this Netgear router is so persnickity about it's compatability.
I appreciate you spending a bit of time with me on this.
Regards, Susan
MommaRoth
Nov 08, 2016Aspirant
Hi ElaineM
So I erased the drive and then Mac OS extended journaled the partitions off - 3T & 2T. Still nothing. I then split down to 1T, then split to 500GB and then, finally 16GB (the size of the USB stick i tried initially & which it was able to read) - all Mac OS extended journaled. Still nothing.
(for the record, when it's plugged directly into my computer it works fine. It's just the router that doesn't recognize the HDD in any of these formats)
I did some digging and found that it might need a driver: http://www.seagate.com/support/software/paragon/
Followed all the instructions & it still isn't recognized through ReadySHARE. I am absolutely at a loss. I would appreciate any thoughts you, or anyone else, might have before I return this! (oh for goodness sake, am I even going to be able to return it now that I've worked on it??)d
TiA - Susan
ElaineM
Nov 09, 2016NETGEAR Employee Retired
It just answers that the router cannot handle such drive.
- MommaRothNov 18, 2016Aspirant
Hi ElaineM
Regards, Susan
- ElaineMNov 18, 2016NETGEAR Employee Retired
You are very welcome.
I hope you'll get this working soon.
