kevinluebke
Feb 13, 2023Guide
Nighthawk r7350 Timing Out Alexa from Yamaha Soundbar
Firmware version 1.2.0.88 using app on Iphone XR 16.2 I have a Yamaha YAS 209 that uses Alexa. Ever since installing my Nighthawk Router, the Alexa feature on the Yamaha app always times out before...
Feb 14, 2023Guru - Experienced User
What modem/gateway is the router connected to?
Are you making sure your phone you're using for the setup is connected to the R7350's 2.4ghz network?
kevinluebke
Feb 14, 2023Guide
It is a Spectrum DOCSIS modem, and yes to the 2.4. The soundbar will only operate on 2.4.
- plemansFeb 14, 2023Guru - Experienced User
What spectrum modem is it?
Did you manage to get it setup but its timing out while using it?
Or timing out during setup?Is ipv6 enabled?
- kevinluebkeFeb 14, 2023GuideThe only information is Spectrum ES2251 DOCSIS 3.1. This is the same modem that was at a secondary location when I tried the sound bar and Alexa worked. The only difference was the router, which is why I think the Router is timing out the request somehow.
The soundbar connects to the WiFI, just will time out when trying to login to Alexa.
I will need to check on IPV6 when I get home. What menu of the router is that under?
Thanks.- plemansFeb 14, 2023Guru - Experienced User
here's a guide.
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
