dbl42
Jul 29, 2022Follower
Nighthawk R7350 VPN Service
I have a subscription to IPVanish. Can I install IPVanish on the R7350 router, so I don't have to install the app on every device connected to the router, which is not possible for at least one of my...
- Jul 29, 2022
There is two parts to that puzzle. One is how to put the third party firmware on the router and the second part is how to remove it and put Netgear OEM firmware back on!
Jul 29, 2022Guru - Experienced User
You'd have to check with ipvanish. Using a vpn like that requires putting a 3rd party firmware on the router. Which you won't find out how to do on the official forums.
https://support.ipvanish.com/hc/en-us/articles/115002080073-Routers
Kitsap
Jul 29, 2022Master
