buzbard
Aug 03, 2022Tutor
Nighthawk R7450 Lost local network after firmware update
After updating my router's firmware to V1.2.0.92_1.0.1, I have lost all local network connections. I have 4 Windows 10Pro PC's connected, they all still have internet access, but are not able to see...
- Aug 03, 2022
buzbard wrote:
Yes network is still set to private.
Tried the network troubleshooter in Windows?
It used to be a joke but has been getting better/
Have you tried typing the device addresses into Windows Explorer?
Devices have a habit of going AWOL. They suddenly sprint into view if I do that. One reason why I keep shortcuts to the rest of the network, PCs and NAS stuff.
Aug 03, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- buzbardAug 03, 2022Tutor
Just tried all that again with no luck.
Disconnected power to both modem and router, and waited 5 minutes.
I powered up the modem and waited for the internet connection (about 3 minutes), then I connected power to the router and powered it up.
I then waited another 5 minutes before checking network connections.
When I open Windows Explorer and click Network, I can see the PC that I'm currently on plus the R7450 (Gateway), modem "ZyXEL APS" and printer (Brother HL-L2360D series) and that's all.
