hackR
Apr 26, 2021Aspirant
Nighthawk R7450 remote management not working, not opening port
Have a Nighthawk R7450 wifi router, firmware v1.2.0.76... I can't get remote management to open the designated port on the router...I check the box for remote management, enter the port 35353, fo...
antinode
Apr 26, 2021Guru
Connected to what?
> [...] when i use the external ip address [...]
Does that (unspecified) "the external ip address" match the IP
address of the router's WAN/Internet interface?
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
> [...] it times out b/c the port is closed... [...]
"it"?
_Which_ "the port"? Are you using "https://" or "http://"?
hackR
Apr 27, 2021Aspirant
connected to: Spectrum cable modem via ethernet cat 6 cable...
external ip address: the external WAN ip address - verified with canyouseeme.org...not the 192.168.1.1 internal address...
it times out: the request to the external address/port combo entered into the browser to access the router remotely...
https or http: https...the remote management router screen defaults to https..and i used that, along with the port 35353...
- antinodeApr 27, 2021Guru
"Spectrum cable modem" is not a useful description of anything
Maker? Model number? Is it actually a modem, or is it a modem+router?
> canyouseeme.org...not the 192.168.1.1 internal address...Too vague to be useful. Are you trying to say that the address you
get from canyouseeme.org is a public address, or that the actual
WAN/Internet address of the router matches that address, or what?> [...] the remote management router screen defaults to https [...]
Only "https://" should work remotely, not "http://".
If you're actually doing things correctly (which is not clear), and a
time-out is all you can get, then you might try loading a
different/older firmware version.
