Spike811's avatar
Spike811
Follower
Apr 06, 2023
Nighthawk R7450
Router will not recognize Ethernet ports. I would like to use wired connections for a couple of devices but the router will only allow wireless ?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Swap out LAN cables between devices.
    Be sure to power cycle the router OFF for 1 minute then back on.
    Try a factory reset and setup from scratch using a wired PC and web browser.
  • michaelkenward's avatar
    michaelkenward
    What does that mean?
    What are these devices that you plugged into the Ethernet ports?
    Take us through the steps you take and what happens.
