RonnieN
Jul 10, 2023Follower
Nighthawk R7450
It won’t allow me to change my Wi-fi Password, keeps saying check connection with router and the options are try again or update router credentials, please help
- microchip8Masterchange password where? Using the app or http://routerlogin.net ?
RonnieN wrote:
It won’t allow me to change my Wi-fi Password, keeps saying check connection with router and the options are try again or update router credentials, please helpManuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Change the WiFi Password or the WiFi Security.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
