CaJazzman
Jan 10, 2016Tutor
Nighthawk R7500 keeps soft rebooting everyday around the same time.
I used to have a netgear wireless N 150 WNR 1000 v2 router and it was soft rebooting every day around the same time. So, I thought and was told I needed a new router. So, I went out and bought a Netg...
- Jan 18, 2016
I use an UPS with mine and my entertainment center to ensure it stays up during a power outage.
LeeH
Jan 10, 2016Prodigy
Could it possibly be the power dropping out?
- JamesGLJan 11, 2016NETGEAR Employee Retired
When you say soft reboot do you mean the router turns off and on or is it the connection drops? If the connection drops, same with the previous router, connect a computer directly to the modem and observe if connection is stable.
- CaJazzmanJan 18, 2016TutorNot sure about the power dropping off, but since I see a couple of the flashing lights to go from white to orange, that maybe be why. Ho would I fix this?
- LeeHJan 18, 2016Prodigy
