dualsweat's avatar
dualsweat
Nighthawk R7500 Slow WebUI
Hi All,                 I recently purchased "2" Nighthawk x4 R7500 Routers to replace "2" WNDR3700's. I upgraded both of the R7500's with the latest firmware (1.0.0.94), and also performed the h...
  • Babylon5's avatar
    Babylon5
    Oct 07, 2015
    Can I ask what the DHCP range of router 1 is set to? This would normally start at 192.168.1.2?
    Personally, I set all my static IPs at the end of the DHCP range, e.g. I set DHCP to end at address 99, and then set static IPs at easy to remember numbers – say increments of 10.
    It might be worthwhile setting the static IP of Router 2 to a much higher number, using the method that TheEther has suggested (which may also need a factory reset or a static IP at the PC since Router 2 is not configured as a DHCP server).
