dualsweat
Oct 05, 2015Aspirant
Nighthawk R7500 Slow WebUI
Hi All,
I recently purchased "2" Nighthawk x4 R7500 Routers to replace "2" WNDR3700's. I upgraded both of the R7500's with the latest firmware (1.0.0.94), and also performed the h...
- Oct 07, 2015
Can I ask what the DHCP range of router 1 is set to? This would normally start at 192.168.1.2?
Personally, I set all my static IPs at the end of the DHCP range, e.g. I set DHCP to end at address 99, and then set static IPs at easy to remember numbers – say increments of 10.
It might be worthwhile setting the static IP of Router 2 to a much higher number, using the method that TheEther has suggested (which may also need a factory reset or a static IP at the PC since Router 2 is not configured as a DHCP server).
Babylon5
Oct 09, 2015NETGEAR Employee Retired
I don’t think Matt has access to the UI (Post 8), so can't get to the UI page where the save settings option lives.
Matt, if you set a static IP address at the PC on the same subnet as your LAN e.g. 192.168.1.111 Subnet mask 255.255.255.0, all other IPs don’t care – leave blank. Then connect by Ethernet to Router1 with nothing else connected i.e. off your LAN, can you access the router at http://192.168.1.1 ?
If that still fails try changing the PC IP to 10.0.0.111, I’m thinking that possibly the router has automatically changed its LAN subnet to avoid a conflict, depending on how you initially set it up.
dualsweat
Oct 09, 2015Aspirant
Hi All,
Thank you for all the tips. Before I did the reset I tried using the power button on the back of the router and powercycled router1. This had no impact and the WebUI still didnt work completely. I let the router sit for a couple hours (because I was working and couldnt do the reset right at that moment). A couple hours later I decided to completely unplug the router from the wall and try again. And, success! I dont know what the difference is between using the power button and completely unplugging the router, but it seems something got "unstuck" by doing it that way.
Problem solved - case closed!
Thanks Again,
Matt M.--------
