Dcolewizard
Jan 19, 2018Aspirant
Nighthawk R7500 Wired connection slow
I recently upgraded my internet from Charter Spectrum 60Mbps to 100Mbps. I noticed that my internet has bee spotty and dropping connection frequently and had them reprovision my modem. Hook up my cable to it and get 96mbps down. All good. However as soon as I plug my computer into the Lan port on my router it drops to 26-29. I can connect my phone to the wifi and get 35+. I have reset, rolled back firmware and even disabled wifi broadcast and can not bring up my lan port speeds. I know it's not the cable as I get around 90+ straight through the modem and when I check the QOS speeds it is registering my bandwidth at 112. What can I do?
My best guess now, after some more testing, is that the 128k buffer in the switch in the router is where the issue is at. Going from >100Mbps to 100Mbps, the buffer in the switch is a choke point.
So the fix: (1) get your computer to operate at 1Gbps ethernet, or (2) if you need to operate your computer at 100Mbps ethernet, try putting a switch with a much larger internal buffer (like the GS116) between you and the router and hopefully that eliminates the problem.
Dcolewizard wrote:
....when I check the QOS speeds it is registering my bandwidth at 112. What can I do?Have you tried turning off QoS?
Also the traffic meter if it is turned on.
- DcolewizardAspirantYes QOS is indeed off. I even turned it on, then back off. Traffic monitoring on and off. I have factory reset the router. Rolled back firmware, re updated the firmware. Tried different cables, tried different ports. I am still at a loss.
One thought, unlikely I know, but are there any 100 Mbps LAN ports on any of these devices?
- duckwareProdigy
The problem might be: there is some ethernet connection operating at 100Mbps but your Internet speed is faster than that (112Mbps) -- and then things can back up and packets get dropped on the floor, causing retries, and what looks to be horrible connection speed.
Just make sure everything in your ethernet network is 1Gbps capable.
Thanks Duckware for your input however I hooked up the R7000 and used the same setup as the R7500 and find that it is providing faster WLAN Speed tests and giving me near my full LAN speeds.
- duckwareProdigy
The two router models are likely buffering differently (different queue depths). With a LAN speed of 100Mbps, you will see dropped packet and retry issues on a 112Mbps Internet connection. Use WireShark to see this.
The big clue is you are saying your comptuer says 1Gbps, but the router says 100Mbps. Both must show as 1Gbps.
