Nighthawk12
Feb 17, 2016Guide
Nighthawk R7500v2 constantly dropping wifi
I purchased the Nighthawk X4 AC2350 yesterday and so far it's been nothing but problems. My wired connection is fine but my 2.4ghz connection is disconnecting about every 20 minutes. I even downgr...
- Mar 02, 2016
Sorry for the late reply but I ended up returning the R7500. I purchased the R8000 instead and I've had no problems at all.
LeeH
Feb 17, 2016Prodigy
Yep. You are probably using channel 1 on the 2.4 GHz. Try channels 6 or 11 and see if that helps.
