Nighthawk12
Feb 17, 2016Guide
Nighthawk R7500v2 constantly dropping wifi
I purchased the Nighthawk X4 AC2350 yesterday and so far it's been nothing but problems. My wired connection is fine but my 2.4ghz connection is disconnecting about every 20 minutes. I even downgr...
- Mar 02, 2016
Sorry for the late reply but I ended up returning the R7500. I purchased the R8000 instead and I've had no problems at all.
warbler
Feb 18, 2016Guide
The new firmware for the R7500 V2 is 1.0.2.2. I have no problem with wifi either 2.4 or 5G.
- Nighthawk12Feb 18, 2016Guide
Switching channels yielded the same results. The 2.4 will still drop and eventually reconnect on channels 6 and 11. I was on firmware version 1.0.2.2 when I first experienced these problems.
- netwrksFeb 18, 2016Master
Nighthawk12 wrote:Switching channels yielded the same results. The 2.4 will still drop and eventually reconnect on channels 6 and 11. I was on firmware version 1.0.2.2 when I first experienced these problems.
You are resetting the router to factory default, each time you change firmware, correct?
Yes, I reset to factory default.
