Nighthawk12
Feb 17, 2016Guide
Nighthawk R7500v2 constantly dropping wifi
I purchased the Nighthawk X4 AC2350 yesterday and so far it's been nothing but problems. My wired connection is fine but my 2.4ghz connection is disconnecting about every 20 minutes. I even downgr...
- Mar 02, 2016
Sorry for the late reply but I ended up returning the R7500. I purchased the R8000 instead and I've had no problems at all.
warbler
Feb 18, 2016Guide
The new firmware for the R7500 V2 is 1.0.2.2. I have no problem with wifi either 2.4 or 5G.
Nighthawk12
Feb 18, 2016Guide
Switching channels yielded the same results. The 2.4 will still drop and eventually reconnect on channels 6 and 11. I was on firmware version 1.0.2.2 when I first experienced these problems.
- netwrksFeb 18, 2016Master
Nighthawk12 wrote:Switching channels yielded the same results. The 2.4 will still drop and eventually reconnect on channels 6 and 11. I was on firmware version 1.0.2.2 when I first experienced these problems.
You are resetting the router to factory default, each time you change firmware, correct?
- Nighthawk12Feb 18, 2016Guide
Yes, I reset to factory default.
- TheEtherFeb 20, 2016Guru
Nighthawk12 wrote:Yes, I reset to factory default.
Are the disconnections happening with one device or multiple devices?
How far away is the router from the device(s)? Are there any intervening walls? If so, what is the construction (e.g. concrete, drywall, brick)?
Check the signal level on your device(s). There are free programs like vistumbler.net, Acrylic Wi-Fi, and Airport Utility that can report signal levels. Note, the Airport Utility looks like it's designed to be used only with Apple's Airport Express router, but it has a simple Wi-Fi scanner that you can enable in settings. On a Mac, Option click the Wi-Fi icon on the top right to reveal detailed data about the Wi-Fi connection, or look at the Wi-Fi section under System Information, or run Wireless Diagnostics.
