jahn28
Mar 21, 2019Tutor
Nighthawk R7500v2 Constantly Restarts
Router Hardware:
Nighthawk X4
AC2350
Model # R7500V2
Firmware: 1.0.3.40
Link: https://www.netgear.com/support/product/R7500v2.aspx
Modem Hardware: CM700 High Speed Cable Modem
D0CSIS 3...
- Mar 22, 2019
> I found out that when Spectrum came to set-up the internet, they set
> the router and modem for me with the power bricks swapped.Trust no one, I always say. According to their User Manuals:
CM700: 12VDC, 1A
R7500v2: 12VDC, 3.5AI would not be amazed if your R7500v2 was feeling a little starved on
a 1A power supply. Thanks for the report.
Mar 21, 2019Guru - Experienced User
Sounds like you've hit most of the basics. You could try downgrading to a prior firmware to see if it brings the stability back. If it does, skip the most recent firmware. If it doesn't you could see if its possible a bad power supply causing the issues.
shadowsports
Mar 21, 2019Hero
How you upgrade your FW is almost as important as what rev you run. Yes, follow plemans suggestion, and manually reflash, reset and confgure your device from scratch. Its perfectly acceptable to reflash the same version FW over itself, go back, forward, etc without ill effects. I haven't been following R7500v2 FW, so I cannot comment on which might be the most stable.
