jahn28
Mar 21, 2019Tutor
Nighthawk R7500v2 Constantly Restarts
Router Hardware:
Nighthawk X4
AC2350
Model # R7500V2
Firmware: 1.0.3.40
Link: https://www.netgear.com/support/product/R7500v2.aspx
Modem Hardware: CM700 High Speed Cable Modem
D0CSIS 3...
- Mar 22, 2019
> I found out that when Spectrum came to set-up the internet, they set
> the router and modem for me with the power bricks swapped.Trust no one, I always say. According to their User Manuals:
CM700: 12VDC, 1A
R7500v2: 12VDC, 3.5AI would not be amazed if your R7500v2 was feeling a little starved on
a 1A power supply. Thanks for the report.
jahn28
Mar 22, 2019Tutor
So for anyone that's reading this:
I found out that when Spectrum came to set-up the internet, they set the router and modem for me with the power bricks swapped.
I'll be testing this further during the day, but hopefully this is the reason why the router keeps restarting.
antinode
Mar 22, 2019Guru
CM700: 12VDC, 1A
