oACGo
Jan 26, 2025Aspirant
Nighthawk R760P VPN Connects, but I can't connect to local PCs
Hello, I have a Nighthawk R760P. My goal is to be able to remotely connect to a Windows shared folder from my Android phone and/or from my MacBook Pro when I am not on my home network, and also to ...
michaelkenward
Jan 27, 2025Guru - Experienced User
Not something that I can find in the Netgear catalogue. Not even anything R76XX.
I can't tell if you have tried this already, but manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
A quick search for OpenVPN could help to pin down what you can and can't do with it.
If you haven't tried it already, there is a lot here:
Search - NETGEAR Communities – OpenVPN
Just another user with time on their hands.
oACGo
Jan 27, 2025Aspirant
My mistake, sorry. It's the R7960P. I have indeed read the manual (referenced it in my post) and numerous community posts, but I could find a clear answer about my situation. Hoping someone can help me solve it. Thanks!
