Josu_Goros
May 05, 2017Aspirant
Nighthawk R7800 - Imposible regirter router in ReadyCloud
Model: Nighthawk X4S AC2600 (R7800) Firmware: V1.0.2.28 (Latest) I have created a new account from here, which gives me access to the MyNetgear account. Next step should be register to the Read...
- Jun 23, 2017
I've detected the problem.
As can be seen in the picture (but I didn't stated in the first post), the router was configured in AP MODE, which doesn't detect properly internet connection to connect succesfully to ReadyCloud (having an active connection obviously).
Configuring the router in standard or router mode, the ReadyCloud registering process has no problem at all.
I think this should be fixed, to be able to register the router also in AP MODE.
Best regards,
michaelkenward
May 06, 2017Guru - Experienced User
You did click the bit that says:
"If you dont already have a ReadyCLOUD acccount...."
Josu_Goros
May 06, 2017Aspirant
Sure.
It redirects to the web url said before in the creating account step.
The url is: https://readycloud.netgear.com/client/en/welcome.html#page=access
- JamesGLMay 09, 2017NETGEAR Employee Retired
Hi Josu_Goros,
Use the email address you used when creating an account as the username when registering.
- Josu_GorosMay 11, 2017Aspirant
As I have said on my first post, is the first thing I did it, with no success.
My email is @hotmail. Just in case, I tested it also with a Gmail account but also the same error appeared.
It is possible to log in the router in ReadyCLOUD another way? It seems a firmware bug that only occurs in this model (R7800 / X4S).
- mondenathMay 11, 2017Prodigy
it usally dont login . If you are having issues check the dns and network. It should work.
did you first able to login to readycloud account.
