j666gak's avatar
j666gak
Tutor
Dec 21, 2016
Nighthawk (R7800) - Unable to upgrade firmware
Hi,   I am currently on firmware version 1.0.1.16. When I press the button on the admin interface to check for firmware updates, it responds saying there are no updates available.   However, I de...
  • j666gak's avatar
    Dec 28, 2016
    A noob error on my part by the looks of it i'm afraid.... I have a D7800 and not the R7800. Although the only difference between the 2 is one includes a modem and the other is only a router.
    So, it would appear Netgear are using two different versions of firmware for both the D7800 / R7800.
