thompssp
Jan 23, 2021Tutor
Nighthawk R7800 1.0.2.80 firmware issue
I just updated my router to firmware version 1.0.2.80 through the Nighthawk app today and now my router restarts on its own every few hours. I did not have this issue with 1.0.2.78. I shouldn't have ...
paillassou
Jan 26, 2021Apprentice
- thompsspJan 27, 2021Tutor
Thanks for replying. I just unplugged it and I'm no longer using it. I'm using my Verizon G3100 now for my wifi. It works better and has no issues. Too bad that Netgear can't do updates without messing stuff up.
- FragelFeb 08, 2021Aspirant
I have the router in AP Mode as well I experience the same problem. I've tried many things and do a lot of search. My 2 cents:
Updating to 1.0.2.74, 76, 78 and 80 introduces a bug leading to random reboots. This happens several times per day. Today, the only way back I have to get back an stable devices is by reflashing a previous 1.0.2.74 firmware (1.0.2.68 for example).
Also, I tried the well-known Voxel's custom firmwares, but they have the same behaviour on those versions based on Netgear's 1.0.2.74 onwards.
From Voxel's, I just tested 1.0.2.80SF and 1.0.2.81.1SF versions. The Voxe'ls 1.0.2.79SF works fine (dated from 23/07/2020 which is based on Netgear's 1.0.2.68).
P.S.: Netgear, please test before publishing updates supposed to improve a product. Some of us use this router with a professional purpose.
This is not an isolated case. Just do a search on the Internet.
Please mind this message and ignore my previous one, which I cannot delete or edit.
I have the router in AP Mode as well and I experience the same problem. I've tried many things and do some research on this topic. My 2 cents:
Updating to 1.0.2.74, 76, 78 and 80 introduces a bug leading to random reboots (at least in AP Mode). This happens several times per day. Today, the only way back I have to get an stable device is by reflashing a version before to 1.0.2.74 firmware (1.0.2.68 for example).
The Voxe'ls 1.0.2.79SF works fine (dated from 23/07/2020 which is based on Netgear's 1.0.2.68). I'm testing 1.0.2.80SF which I believe is the latest Voxel's version based in Netgear's 1.0.2.68, so I should not find issues if my assumptions are right.
