thompssp
Jan 23, 2021Tutor
Nighthawk R7800 1.0.2.80 firmware issue
I just updated my router to firmware version 1.0.2.80 through the Nighthawk app today and now my router restarts on its own every few hours. I did not have this issue with 1.0.2.78. I shouldn't have ...
Fragel
Feb 08, 2021Aspirant
Please mind this message and ignore my previous one, which I cannot delete or edit.
I have the router in AP Mode as well and I experience the same problem. I've tried many things and do some research on this topic. My 2 cents:
Updating to 1.0.2.74, 76, 78 and 80 introduces a bug leading to random reboots (at least in AP Mode). This happens several times per day. Today, the only way back I have to get an stable device is by reflashing a version before to 1.0.2.74 firmware (1.0.2.68 for example).
Also, I tried the well-known Voxel's custom firmwares, but they have the same behaviour on those versions based on Netgear's 1.0.2.74 onwards.
The Voxe'ls 1.0.2.79SF works fine (dated from 23/07/2020 which is based on Netgear's 1.0.2.68). I'm testing 1.0.2.80SF which I believe is the latest Voxel's version based in Netgear's 1.0.2.68, so I should not find issues if my assumptions are right.
P.S.: Netgear, please test before publishing updates supposed to improve a product. Some of us use this router with a professional purpose.
This is not an isolated case. Just do a search on the Internet.
ablatt
Feb 09, 2021Apprentice
1.0.2.80 works for me in AP mode. So did 1.0.2.76. Never tried .78, Been up steady for five days, but I will watch it.
I'm not saying you're not having the issue, but it does work for some people. Perhaps try some of my settings below and see if one of them makes a difference.
I download the update and perform the update in the GUI using an Ethernet connection.
I then hold in a paperclip in the back for 15 seconds and let the device reboot.
I set it up manually in AP mode - using a fixed IP address, not DHCP.
My other options are:
- use the WAN port for the connection to my router
- no DFS channels
- no Smart Connect
- Beamforming on
- no MU-MIMO
- no HT160
- no Media Servers
- paillassouMar 30, 2021Apprentice
HELLO
fyi 1.0.2.82 is out
https://www.netgear.fr/support/product/r7800.aspx#download
i'm gonna try asapBye
- thompsspMar 30, 2021Tutor
Thanks for the reply. Let me know how it works out. That last firmware update really screwed up my Nighthawk router. I've just been using my Verizon G3100 router and have had zero issues so far with the same coverage my Nighthawk had.
