Koala_b
Dec 26, 2020Aspirant
Nighthawk R7800 "10.0.0.1..." or "192.168.1.1 didn't send any data"
First intallation of a new R7800. I've begun with the router connected to internet though a modem-box (fiber access). A message said that the router has been set to the 10.0.0.1 address (due to con...
Dec 26, 2020Guru - Experienced User
have you tried simple putting the router in access point mode to avoid the double nat issue?
- Koala_bDec 26, 2020Aspirant
As the issue occurs too when the R7800 is not connected to the internet modem (so, theoretically in a situation without double NAT issue) I doubted about this raison... But, as I finally want to use it as an Access Point, I gave it a try: I've redone a factory reset, and I immediatelly set the router as an Acces Point (so, before to change any Wifi parameters).
That's worked: I'd access to the admin interface, and was able to change the Wifi parameters right after as I wanted in the first place.
So, for me, that means that the issue occured because some data are not correctly swept between 2 changes in the administration of the router...
But the story is not ended: now I face 2 other issues that seem common for the Netgear routers (if I trust the amount of the users' complaints on this forum)...
1) The router does a random reboot by its own,
2) While the PC under Windows 7 and 10 seem to have access to Internet, the 2 iPhones 10 in the house have no access to internet, detailled message saying that the certificate hold on www.routerlogin.net is 'Not trusted'...
Franckly, I don't remember the last time I had to spend so much hours to try to install a router or to set an electronic device...
If not solved by tomorrow, this router will be put on a shelf (waiting for a new firmware?) or will go directly to the bin, and another router will be purchased but, for sure, from another brand than Netgear...
- plemansDec 27, 2020Guru - Experienced User
maybe you have corrupt firmware in your device. Have you given downgrading the firmware a version, doing a factory reset, and a reinstall? (do a clean install, not from backup). Then disable aut0-updates.
The r7800's been one of the more solid routers netgear makes and gets recommend on here a lot. so I'd work on it a little bit.
- Koala_bDec 29, 2020Aspirant
Thanks for your advice, but I already done many factory resets until now without much success, so I'm a little tired of this item (even if, I know, it has a good reputation) and I prefer to wait for a manual update with a future Firmware (v1.0.2.79?).
In the meantime, I've purchased a second hand AC3100 router (Asus RT-AC88U) than I found in my neighborhood:
- 30 minutes to pick it up and go back home,
- 9 minutes to unpack, load last Firmware, and set Admin password + my past Wifi SSID/passwords,
- All the Wifi repeaters, PCs and mobile phones got immediate access to the house network and to Internet,
- Since 2 days, no strange auto reboot, no Certificate issue on iPhones.
Efficiency makes all the difference... :smileyhappy:
