JanVegas
Aug 14, 2023Aspirant
Nighthawk R7800 capabilities
 Recently upgraded internet from up to 200mbps to 1000mbps, but there is no difference in speed on a Dell Optiplex 5070.     Just want to know if the Nighthawk X4S AC2600 (Firmwear version: V1.0.2.92)...
JanVegas
Nighthawk X4S AC2600 firmware version is 1.0.2.92. Cox modem - Arris CM8200A. No markings on cable from internet modem to router; however, it is small diameter than the CAT6 cable going from router to PC.
All of the things mentioned in your list have been done but not in the order specified; however, I gather that your estimation is that the router is capable of 1G provided the setup is done correctly. So that answers my question. Please let me know if you see any issues with the above-mentioned equipment. (No news is good news.) Many thanks for the reply.
Aug 14, 2023Guru - Experienced User
If there are not markings on the cable, would be anyone's guess about that cable kind. I recommend you find and replace the cable to be sure with a CAT6 cable.
Yes the R7800 is capable of handling around 900Mpbs which is what you should see with a ethernet connected PC.
- JanVegasAug 14, 2023Aspirant
Will replace cable from cable modem to router with high quality CAT6 and go from there with properly ordered instructions provided. Many thanks for your time and expertise.
- FURRYe38Aug 14, 2023Guru - Experienced User
Another test would be to connect a wired PC directly to the ISP modem and speed test there to ensure your getting to spec speeds there.
- KitsapAug 14, 2023Master
When you are doing throughput testing, recommend you download the Ookla stand alone application from the Windows play store. This application takes the web browser application out of the test path.
Your R7800 is fully capable of supporting a 1 Gbps local area network over Ethernet. Real world throughput will run around 920 to 950 Mbps due to hardware efficiency.
