Preciousk2011
Jan 18, 2024Aspirant
Nighthawk R7800 does not show bandwith or set devices to low medium- high even after apply?
Arrg, I cannot see bandwith on any device under attached devices. I cannot set priority low, led, high for any device either. Under the Qos, I cannot update the data it is dated back to 2017? It keeps...
Jan 18, 2024Guru - Experienced User
The database for QoS was discontinued years ago. NG doesn't maintain that anymore.
Check out some Voxel FW for this moderl router as he maintains it for the R7800.
Kitsap
Jan 18, 2024Master
Voxel home page is here: https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Before installing, carefully review the Readme section on the top banner. The R7800 firmware is under the X4S section.
