Slapchop
Nov 20, 2021Aspirant
Nighthawk R7800 looks to be bricked. At my wits end.
 I've been trying all morning and afternoon to get my Nighthawk router back online after a bricked firmware update. I have a white light on the power led and it flashes. I'm trying to use TFTP2 with a...
- Nov 21, 2021This issue is now solved. I followed the instructions here https://www.youtube.com/watch?v=XeoS0xVINOE and was able to flash my firmware sucessfully and get my Nighthawk back up and running. For anyone having these issues. FOLLOW THIS VIDEO.
michaelkenward
Nov 21, 2021Guru - Experienced User
Slapchop wrote:
It works at first and loads about 75% of the way then I get a "Unable to get responses from the server" error
I have TFTP'd an R7800, albeit not one with broken firmware. (It was some magical intervention during a beta test.) But I do know that TFTP can be a tricky operation that can take several attempts.
Apart from the timing, a particular issue can be the location of the firmware and the place where you start the TFTP session. Ideally, they should be the same place. You don't want to be faffing around with "directory" (path) instructions in the TFTP commands you issue. Start the process from the directory where the firmware sits.
I'm trying to use TFTP2 with a lower firmware to try and reflash it.
Why TFTP2? You would be better off using the native TFTP in whatever (unknown) operating system you are using.
Netgear's TFTP guidance tells you how to set it up in Windows with a pointer to Macs.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
By the way, you may be able to prod the router into "recovery mode".
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that works the standard firmware flash may work.
Slapchop
Nov 21, 2021Aspirant
I tried TFTP orignally and wasnt able to get it to work. I got the same error message as before. No responses from servers I beleive was the message. Like I said in my first post I've been trying everything to try and get this back online. I've put the router into "recovery mode" or at least did those steps. I've gotten a solid orange power led and the standard flashing white led.
- plemansNov 21, 2021Guru - Experienced UserDid you run the command prompt as an administrator? Right click on it and "run as administrator" when tftp had issues, what error were you getting? details are key with helping on these
- michaelkenwardNov 21, 2021Guru - Experienced User
 Slapchop wrote:
 I've gotten a solid orange power led and the standard flashing white led. Which is it? Blinking amber is corrupt firmware. A flashing white led get you into TFTP recovery mode. That's where you want to be. - SlapchopNov 21, 2021Aspirantcurrently just the flashing white led. Same issues as above trying to load the firmware - SlapchopNov 21, 2021AspirantThis issue is now solved. I followed the instructions here https://www.youtube.com/watch?v=XeoS0xVINOE and was able to flash my firmware sucessfully and get my Nighthawk back up and running. For anyone having these issues. FOLLOW THIS VIDEO.
