pinkbeat's avatar
pinkbeat
Nighthawk R7800 Needs to be restarted several times to connect to internet
Hi, can't find info on the internet so I came here. My Nighthawk R7800 is two years old. Sometimes I find that I can't stream and find the WiFi signal is way, way low so I have to restart my router. ...
  • microchip8's avatar
    microchip8
    Aug 15, 2019
    Have you tried a factory reset and configure from scratch? My R7800 is also almost 2 years old and works fine (currently at 36 day of uptime without issues). I use the .63 hot fix firmware, though, but also didn't have problems with the .62 one
