pinkbeat
Aug 15, 2019Aspirant
Nighthawk R7800 Needs to be restarted several times to connect to internet
Hi, can't find info on the internet so I came here. My Nighthawk R7800 is two years old. Sometimes I find that I can't stream and find the WiFi signal is way, way low so I have to restart my router. ...
- Aug 15, 2019
Have you tried a factory reset and configure from scratch? My R7800 is also almost 2 years old and works fine (currently at 36 day of uptime without issues). I use the .63 hot fix firmware, though, but also didn't have problems with the .62 one
microchip8
Aug 15, 2019Master
pinkbeat
No, I haven't tried a factory reset. Maybe I'll try that tomorrow. I'll report back.
- pinkbeatAug 16, 2019Aspirant
Okay, I did the factory reset and reentered my set up stuff. Turned it off and on and it connected.Hopefully it will be that way when I need to reboot it again. Thanks for the suggestion. I appreciate it.
