jrc3099
Jun 16, 2021Aspirant
Nighthawk R7800 no internet connection for office. STATIC IP
Hello, We're trying to set up a router in our office. We have a server room which we have been setup in. When we connect at the wall the lights show that we have signal. I'm able to connect to the r...
jrc3099
Sorry for the lack of information. This sort of stuff is outside my scope of knowledge. Our ISP is a company called GoNetSpeed, essentially they provide a fiber optic circuit to the server room. So we hav a cat 5 cable going from the internet port on the router to the activated port in our office that is connected to the provided modem. On the face of the router the internet light is lit as well as the 2.4 and 5G lights are lit as well. I'm able to connect to the router's WiFi but it says connected with no internet access. I'm able to go through the whole setup process with the nighthawk app as well as the advanced setup when I log in through the browser window. I've used the manual and have tried the setup process as shown in the manual for setup for a static IP and am still not able to connect.
This was the info provided to us:
Customer WAN IP address: 38.126.110.29
Subnet Mask: 255.255.255.252
WAN IP Gateway address: 38.126.110.30
DNS Resolvers:
8.8.8.8
66.28.0.45
66.28.0.61
Thanks for the help, sorry for my lack of knowledge
antinode
Jun 16, 2021Guru
> On the face of the router the internet light is lit [...]
Which color is "lit"? White? Amber? Other?
> [...] Get the User Manual (at least). Read. [...] look for the LED
> descriptions [...]
Did you? Did you notice the colors mentioned there?
> [...] Our ISP is a company called GoNetSpeed [...]
Did you ask them about this? Presumably, you're not their first
customer, and you're paying them a small fortune. I'd try to get
something for my money.
You have an atypical WAN/Internet configuration, a block of four IP
addresses ("38.126.110.28" - "38.126.110.31"), rather than a single IP
address. (Although the effect is about the same.) The low and high
addresses have special purposes, so only ".29" and ".30" are of interest
to you.
My experience with these routers in that kind of environment is nil,
so I know nothing, but...
If you configured the R7800 with:
BASIC > Internet > Internet IP Address
(o) Use Static IP Address
IP Address 38.126.110.29
IP Subnet Mask 255.255.255.252
Gateway IP Address 38.126.110.30then (with low confidence) I'd expect it to work, especially if its
Internet LED is white.
> [...] I'm able to connect to the router's WiFi but it says connected
> with no internet access. [...]
"connect" _what_ "to the router's WiFi"? What does that device have
to say abut its network interface? IP address, subnet mask, gateway,
DNS, ...? Any difference with a wired device?
Your DNS servers look harmless enough, at least.
> Model: R7800|Nighthawk X4S AC2600 Wifi Router
Firmware version?
- jrc3099Jun 17, 2021Aspirant
As far as lights on the router, the Power, Internet, 2.4ghz, 5ghz, wifi on/off and WPS LED's are all white. The internet light blinks intermittently every 1-2 seconds. I spoke with the ISP and they essentially said they did everything needed on their end and the router was a separate issue. We all work on laptops in our office so any of us who try to connect can see the 2.4 and 5ghz networks but after joining either network it says "Connected, Secured, No internet". Our current firmware version is V1.0.2.78. I really appreciate the help.
Thanks.
