JesseFlo's avatar
JesseFlo
Nighthawk R7800 not showing my WiFi
My WiFi network is not showing up and i cannot connect to the internet. I’ve tried rebooting the router and i checked that i have the latest firmware. It still does not show up when i search for it.
    What about the LED indicators on the front panel?  The second one in from the right is for Wi-Fi on/off.  Is this one illuminated or not?  Farther towards to the left there are indicators labeled 2.4 GHz and 5 GHz.  Are they illuminated?
    The Wi-Fi on/off indicator is a combination indicator/switch.  If it was accidentally turned off, you would not be broadcasting a Wi-Fi signal.  Push and hold for a few seconds to turn off or on.  Rebooting the router does not turn on Wi-Fi if it has been manually turned off via the combination indicator/switch.
    Also when you are logged in to the user interface, it is possible to turn off the Wi-Fi radios from there.  There is one checkbox for the 2.4 GHz and one checkbox for the 5 GHz.
    • JesseFlo's avatar
      JesseFlo
      Thank you. I must have turned off the WiFi via the button. I didn’t notice because i had the lights turned off. Once i turned them on it was clear to see that it was turned off.
