olhado's avatar
olhado
Nighthawk R7800 poor WiFI performance
I use R7800 for almost two years. Until some time ago performance was very good. I have 100/15Mbps internet connection, and I had no problems with the speed. Recently my WiFi performance dropped and ...
  • James721's avatar
    James721
    Sep 27, 2018
    It's not only wifi drops with the new .58  It has a issue with huge ping spikes and latency. This has been confirmed by dozens of people and the tests have been ran. There is no question .58 firmware is faulty.  That said Voxel is a third party firmware that builds on the core GPL of Netgears original code. He adds much needed updates to several outdated packages Netgear uses and also adds features. Info here https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-60sf.48805/  Firmware here. http://www.voxel-firmware.com/Downloads/Voxel/html/index.html   If your not comfortable using third party firmware then simply downgrade back to .52 Netgear firmware it works good minus naming connected clients wich is broke in .52.
